what is voltage output of solar panel?
What is rated Wattage of solar panel?
is there and extension cable for solar panel?
Can solar panel cable be extended?
Can inverting camera with solar panel plugged in cause water(rain) intrusion?
Message 1 of 3
2,982
about 5.8v when tested
unknown
No
No
It shouldn't.... but If I was doing it, I might use coax-seal on connecter or similar ( coax seal is a putty type sealer that is removable if needed )
Thank you
Message 3 of 3
2,946
