timestamp from base station
I noticed the video that gets recorded to my USB stick from the Arlo Base station is timestamped an hour off. How do I adjust the time on the base station?
Are your cloud recordings displaying the correct time of recording? If you go into Settings > My Devices > [name of base station] you should see a timezone setting. Check that's correct
You can try rebooting the base, too.
