reliable solar panel for Arlo Pro 2?
There's the "iTODOS Solar Panel Works for Arlo Pro and Arlo Pro 2, 11.8Ft Outdoor Power Charging Cable and Adjustable Mount,Not for Arlo Ultra and Arlo Pro3 (Black)" on Amazon for $39.99, but the mixed reviews have me feeling doubtful.
If anyone has alternative solar panels that work or has personal experience with the iTODOS above then I'll go ahead and bite the bullet and try it myself. Thanks.
I think this has been explored before. The micro USB port on this one doesn't properly fit the Pro 2 camera. But it's good to see they now provide one type of solar panel for different types of cameras - better for the environment.
You can still occasionally get old new stock of solar panels for Pro and Pro 2 on eBay. For example, on eBay UK, you can get this:
Unfortunately true.
