plans to release cloud service in qatar?
I am using my Arlo pro 2 in Qatar
Unfortunatly there is no plan of cloud in here, Please provide the cloud service for this region.
any plan soon for such a country?
im using arlo for 3 year i cant waiting more i need to use 10 camera i cant
Can you answe Please ?
You may want to submit a case on Alro’s Support site rather than ask here in the Community. Arlo monitors the Community fairly lightly. It is mostly interaction among Arlo owners.
If you are able to use Arlo as a 5 camera system without “a plan” offered specifically for Qatar, You might consider setting up a second Arlo account, installing a 5 camera system on that second account and then sharing access to the cameras on the second account with your primary account. That would allow you two have a ten camera system (sort of), which your could monitor from a single account. You’d just need to administer your second set of cameras from that second account when needed. But you can monitor all 10 cameras on the App from one login.
