cannot view my new VMC2030 cameras on my iphone app.
cannot view my new VMC2030 cameras on my iphone app. downloads to a USB. what can i do? not what we bought this unit to do
Are you saying you can't livestream? Or can't see the recordings?
Do you have a subscription for the cameras? You need one to get cloud storage.
to make sure i understand, the only way to see the library recordings for the 2030 cameras is to subscribe to the cloud?
Is there a newer base that would be compatible with my pro cameras and the 2030 that would accommodate without a subscription? We are on a fixed income and do not want a monthly fee.
also. are pro 2, pro 3 or pro 4 cameras compatible with the VMB4000 base that we can use without a subscription?
That is the only way to see the cloud recordings for the Essential Spotlight cameras.
The Pro / Pro 2 cameras came with free 7-day cloud storage, but Arlo stopped offering that on new models back in 2018.
A VMB4540 or VMB5000 smarthub would let you see locally recorded videos in the app. That also requires at least 16 GB of storage (USB stick for the VMB4540, a MicroSD card for the VMB5000). The Pro cameras could be moved to that base, or you could just run both bases.
There are limitations:
- Recordings only available in the app (not the browser)
- Recordings only available from the primary account (not friend accounts)
- No manual recordings or snapshots
- No thumbnails (surprisingly annoying)
- Remote access requires router setting changes that some find difficult (and isn't possible with some network providers - starlink and tmobile broadband to name two).
You also lose activity zones with no subscription.
As far as the fee goes: List price for the VMB4540 is $99, but I don't think you can find any for that price. I am seeing some VMB4540s available on Amazon for $199 USD. If you only have two VMC2030s, then the subscription would cost $6 per month, so it would take about 33 months to break even on the smarthub. If you need the multicamera subscription, it would cost $10 per month, so about 20 months to break even. Whether that's a good deal or not depends in part on whether you can live with the limitations.
