can I operate my pro 2 from a lap top and wifi and no modem?
  • 1 Reply
  • 1440 Views
larslaxo
Can I operate my pro 2 cameras with a laptop and wifi and no modem? just got this set up and trying to set it up
michaelkenward
Sensei Sensei
Sensei
Not unless you use something else to connect to the Internet.
The Pro 2 stuff works like this.
You have an internet connection, usually through a modem and router.
You plug your Pro Base Station/Hub into the router to get to the internet.
The cameras use wifi to communicate with the hub.
The hub sends your recordings over the Internet to a "cloud" store that feeds you back your recordings when you want to see what has has happened.
Your hub also has a slot for a memory chip. But that's just a backup.
How do I set up local storage backups on a USB device using my Arlo base station?
How do I view videos saved on a local storage USB device?
Just another user
  • 1 Reply
  • 1441 Views
