  • 1 Reply
  • 654 Views
harleyguy1955
I purchased an Arlo Pro 2 system last October.  I have 3 set up, and they work great.  I have two more cameras that I will eventually mount outside.  When one of my camera batteries need changing, I just use my extra battery to swap out.  One of the batteries does not charge in the dual charger from Arlo, it stays yellow on the indicator light.  I put this battery in one of my cameras, and it shows it is completely dead.  I cannot believe it has already gone bad.  Do the batteries eventually just die.  I have used it very little, or do you think it was just a bad battery to begin with, and, does Arlo have a warranty on their batteries.
Thanks.
Warranty , IIRC, is one year... contact Arlo support.
But try this first;
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
  • 1 Reply
  • 655 Views
