arlo 2 cameras
Hi all, thanks for the ad.
My dad has upgraded his security camera and gifted me his arlo 2.
I set the base station up fine but the cameras won't go into pairing mode.
I contacted arlo through their chat and was told they are no longer supported.
I assume they have been bricked.
Is there a way to get these going again or is the system trash now?
Many thanks
Are they still attached to your dads account, if so he would need to remove them from the account before you can add them to your account. Also, do you know which basestation you are using to set up the cameras on?
