Your Camera Needs To Warm Up - Arlo Pro 2 At Bay Area
I'm in bay area and one of my INDOOR arlo camera recently keeps being reported under "Low Temperature" and thus "needs to warm up before you can use it". However, the lowest temperature these days are all above 60F (15C)! If it is still "too" cold, I need to relocate to Florida 😂
Try removing and reconnecting the camera. If it's a hardware issue you need to use the Contact Support link at the bottom here.
When I removed this camera and attempt to reconnect it following the instructions on Apps, the LED on the camera is blinking Orange instead of Blue when pressing the Sync button. Thus in the next step it couldn't be detected ...
Hi nzhao,
If it shows a slow blinking amber LED, there might be an error with how you're connecting it or the battery may be low. Make sure your camera is not too far from the Base Station when trying to onboard the camera to your account. You can read this article to learn how to troubleshoot: My Arlo camera will not sync with my SmartHub or base station; how can I troubleshoot it?
