Your Arlo Device Appears Offline - Arlo Pro 2
Since yesterday evening my Arlo states "Your Arlo Device Appears Offline". Anyone else having this issue? It has been hooked up for years without issues and no changes have been made. I have done the restart and the power cycle but nothing helps. The status light for the network shows solid green but the Arlo camera status light on the far right is off. Every so often it comes back up on its own but then seems to go back down within minutes. Help!
Yes, I have the same issue. My VMB4000 base station is connected to the internet and works fine, but all four of my Pro 2 cameras have been offline since sometime after 11-18 at 10pm CST. I've had this setup for 3 years with no changes or similar issues. I've tried everything I can think of: power cycle base station, power cycle cameras with new batteries, power cycle modem/router, factory reset and setup everything from scratch, relocate base station to another part of the house in case of interference. Nothing has worked and I'm out of ideas.
Are you still experiencing this issue with your cameras offline?
No, after multiple restarts, power cycling, etc... eventually they just started working again about 2 days later.
