Will the Pro 5s work with a Pro 2 system?
- Considering purchasing Pro5s camera. Will it work with my Pro2 setup. Use usb drive for storage, not interested in monitoring service.
Whether you can connect the Pro 5 to you base depends on the base model. Check the bottom of the base for a sticker that lists VMBxxxx. The VMB3xxx series can't connect with a Pro 5.
As for local recordings, only the VMB4540 and 5000 SmartHubs allow the use of the app to view local recordings. All others require that you eject the drive for viewing on a computer. And the VMB3xxx series can't provide local recordings in the first place.
