Thinking of purchasing the Arlo Pro 2 system, need to know if the cameras from the Arlo pro work with this system and how many cameras can you add?
HI @bballi
The Arlo Smart Hubs & Base stations are compatible with most of the Arlo devices. The Arlo Pro cameras will be compatible with any of the Smart Hubs & Base stations. You can find more info here: What is the difference between each Arlo SmartHub and base station?
Regarding how many cameras you can use, this depends on Features/Subscription. You can find more information here: What are the available Arlo subscription plans and how much cloud recording is available?
