Hello, can someone tell me how I can buy the key to my cameras? I lost it and I can't use the cameras because I can't change the battery
@mcfm wrote:
Hola, alguien puede decirme cómo puedo comprar la llave de mis cámaras? La perdí y no puedo utilizar las cámaras porque no puedo cambiar la bateria
FWIW, the Pro 2 cameras don't use a key - so you posted in the wrong forum area.
Go to a local hardware store and purchase a 2 mm hex wrench. That will fit.
						Arlo Mobile App629
						Arlo Pro 211
						Arlo Smart180
						Before You Buy995
						Features441
						Firmware Release Notes57
						Google Assistant1
						IFTTT (If This Then That)24
						Installation1,148
						Online and Mobile Apps865
						Service and Storage317
						SmartThings37
						Troubleshooting6,322
