Where do I get a new add on camera?
  • 2762 Views
  • 2 Likes
bubbasw
Seems like Arlo Pro 2 is leaving me in a lurch. I need one add on Arlo Pro2 camera and no stores have them now it seems? Anyone know a good source to get one? I like the 4030P because they are smaller.  THX
dcfox1
There isn't even a product page on Arlo for the Pro2. Not sure if they are discontinued or being phased out as there are several models released since the Pro2. there really isn't much difference in the size of the newer camera, but you can try Amazon that may have some refurbished.
Have you tried a Google search? You may end up with a used camera off eBay but I see Amazon has listings.
ant
Mentor
Mentor
A few weeks ago, a new one ordered from eBay. It worked perfectly and came with everything. https://community.arlo.com/t5/Arlo/Need-wireless-Arlo-camera-replacements-that-are-compatible-with/m... for my forum thread about it that will help you especially its links like https://kb.arlo.com/000062284/Arlo-SmartHub-and-Base-Station-Compatibility (be sure you get the correct compatible camera)!
  • 2763 Views
  • 2 Likes
