What is the difference between arlo pro 2 and arlo q / arlo q plus
Look at the products info page at top of screen
Mainly the Arlo Q\Q Plus is not rated for outdoors and seems to be better fit for indoors the Arlo Pro 2 is rated for outdoors, but still works well for indoors as well as it can be completely wireless. The Arlo Q\QPlus needs a power connection. You can compare them here.
Arlo Products
If You Got Em....I'll Chew Em!
Netgear & Arlo Beta Tester
