I was notified of motion by arlo. I started the app and started the camera manually.
The library only shows a still from that timeframe, although the meta data shows 55 seconds was recorded. I would like to see what arlo recorded when I was first notified. (no library filters are set and there is another later video recorded)
Try downloading it and use the free VLC viewer. Any better?
Thank you - worked like a charm. Actually on my iPhone the video was accessible in the photos app. Very easy.
Hi Bill,
Apparently that is the case. I unexpectedly had a visitor that triggered my camera. When I received the notification, I manually triggered the camera to see what was going on. I think you would agree that is a normal reaction.
In going back to review the video that triggered the notification, I was presented with a still photo and meta data saying that there was 55 seconds of video. Based on comments from this board, apparently now the video is only available as a download. Should this have been a true break-in, I agree this is a cumbersome process. Further frustrating is that even though I spent a lot of money on these cameras, since I dont have a subscription, customer support was not interested in hearing about the issue.
Eg. If you use the web portal with a browser you should be able to play the problem video.
Where the iOS app version at least will not play it unless you save it to photos. This is a workaround only.
Unfortunately you are unable to raise a fault case unless you have a subscription plan.
Glad there’s a workaround, but this should get fixed.
