What cameras are compatible with base VMB3500r4?
My father-in-law purchased a PRO 2 system at Costco which has 3 Pro 2 cameras and the VMB3500 base. He would like to add two more cameras. Which cameras are compatible with this base?
You may want to consider the arlo essential since it is able to stand alone. Read carefully.
https://kb.arlo.com/000062416/Arlo-Essential-Wire-Free-Camera-Series-FAQ
Any of the Legacy cameras will work on the 3500 base unit....
Pro, Pro2 and the original Arlo HD ( 123 batteries camera )
You can have a TOTAL of 5 cameras without a plan, with a plan you can run more on the same base
VMB3500
- Compatible with: Arlo Pro 2, Pro, Wire-Free, and Audio Doorbell.
- Maximum streaming resolution: 1080p with a compatible Arlo camera
- Local storage: No
- Integrated siren: No
for full info read this;
https://kb.arlo.com/000062284/What-is-the-difference-between-each-Arlo-SmartHub-and-base-station
