What camera can I buy now as an add on to an ARLO PRO 2 (discontinued)
  • 2 Replies
  • 983 Views
  • 2 Likes
ange0000
Wanting to add one more camera to an existing Arlo Pro2, can't find any information on compatible systems.  Thanks
Best answers
  • dcfox1
    Here is the compatibility list for what cameras work with certain bases/hubs. The Essential mentioned can connect to a base or your wifi.
    Arlo SmartHub and Base Station Compatibility
Dannybear
If you’re after a additional camera then look at the essential.
Be aware that any camera after the pro2 will require a subscription plan for it to fully work.
dcfox1
  • 2 Replies
  • 984 Views
  • 2 Likes
