Activer les suggestions
La fonction de suggestion automatique permet d'affiner rapidement votre recherche en suggérant des correspondances possibles au fur et à mesure de la frappe.
Affichage des résultats de
Weather resistant - under 32 degree Arlo Pro or Arlo Pro2
Répondre
Options du sujet
- S'abonner au fil RSS
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
say it is good between 32 degree and 122 degree
What happen when the temperature get under 32 degree, the freezing poing
1 RÉPONSE 1
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hey @Maine100,
Arlo Pro and Pro 2 batteries minimum operating temperature is -4°F (-20°C) while the Arlo Solar Panel's operating temperature range is 32° to 122°F (0° to 50°C).
To avoid permanent damages and for your safety, make sure not to have your battery charging below freezing as you may receive a error message on the app or web stating you are not able to charge. You can read more about it here: How do I keep my Arlo batteries charged in cold weather?
Étiquettes
79 -
Assistance et stockage
101 -
Avant d'acheter
Communauté Annonces
Géolocalisation
23 -
Notes de publication
- « Précédent
- Suivant »
