Wall mount
@JohnR58 wrote:
Is the old fb1001a wall mount the same as the fb1001-100nas?
The FB1001 is a wireless floodlight camera, it is not a mount.
I have it plugged in to a power supply and mounted on an outside wall. It has problems and I want to replace with new Series Pro 2. I have to climb a ladder 12 feet so I need to know if the old mount will work with the new camera.
I'm confused on what you have.
- The wireless floodlight (FB1001) has an integrated mount that is not compatible with any other camera. Although it looks like Arlo's total security mount, it is actually somewhat different.
- The new wired floodlight (FLW2001) is designed to be hardwired into an outdoor electrical junction box, so it has no mount.
Can you confirm that you have a Pro 2 camera? Also, are you using Arlo's outdoor charger for it? If not, what are you using?
