I have an Arlo system with 4 Pro 2 cameras. Lately I have noticed that when I view two of these cameras recordings, it has periods of time that the video either speeds up or slows down. Why does this happen? And what can I do to prevent this defective recording?
Hey Wattman,
If you're experiencing your recordings speed to be fast or slow, try to test by having the cameras closer to the Base Station and try recording to see if it occurs again. If so, you might want to try rebooting your Base Station to see if that helps.
This needs fixing.
My system has not changed. Something else has.
Hi Joepoodle,
Is this happening on both the Arlo app on your phone device and/or the web client on your computer? You can contact the Support Team with this link. You will find several options for contacting support.
When re-viewing the one particular recording it is oddly fast, slow, or parts missing.....but never the same issue two viewings in a row.
I too have noticed the same thing. The quality is crap from what it used to be.
I have tried rebooting everything. Same crap results.
This is on both the app and watching it on my desktop computer. (via the Arlo website)
Arlo...What happened?
I see the same issue. Every one of my recorded videos start off for the first three seconds in slow motion and then change to normal on their own. I’m doubting it’s the app as the app is only a tool to view content.
Check your base station software version. I found that mine had an update around the same time as the new app came out. I’m guessing it’s the new version of software that was pushed out.
Im also seeing a higher number of video drop outs where the sound keeps recording but the person simply disappears mid motion.
come on Arlo, please fix this. And no, nothing changed on my end!
