  • 10 Replies
  • 2698 Views
ShereeK
I have been having trouble with video playback since I downloaded the new Arlo app on my iPhone 11. Live connection and microphone is much slower. Not allowing me to play back videos that are recorded. Is there a fix for this?
10 REPLIES 10
ShayneS
Hi @ShereeK
Are you still experiencing this issue? What version of iOS is your iPhone running?
TheBollinger
I’m having this exact same issue since the latest update.
ShayneS
Hi @TheBollinger
What version of the Arlo app are you using & what phone/OS version are you running?
TheBollinger
App 2.11.1 (1679)
iPhone 7 on iOS 13.2.3
ShereeK
I am using iPhone 11 13.2.3
My Arlo started working again just this past Monday (December 2nd). Appears to be working as before.
ShayneS
@TheBollinger
  What troubleshooting steps have you tried so far? I do not want to suggest anything you may have previously performed.
TheBollinger
Thanks for asking. So far I’ve tried replacing the batteries on the camera, resetting the application, reinstalling the application, and restarting my phone.
The live video feed from the camera works perfectly fine (I can turn that on and stream no problem), and I receive notifications when a recording is triggered; but if I try to go and view a recorded clip, it’s impossible to select a day and there is no list of recordings underneath any of the days.
My phone’s notification center however shows that the clip has been recorded etc. and the settings in the Arlo app all indicate that they are correct for making such recordings.
ShayneS
@TheBollinger
Can you view/play the recordings from the web portal?
TheBollinger
No, when I log into the web portal, it also shows no recordings.
ShayneS
@TheBollinger
Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
  • 10 Replies
  • 2699 Views
