VMB4500 vs VMB4000 siren
Hi, just bought a new set of 4 Pro 2 cameras including the base station which happens to be the new VMB4500. At the installation i updated the firmware.
All good so far - however the siren is a joke and definitely NOT 100db as advertised. Funny enough also all pictures on Arlo.com etc show a different model, i assume the older VMB4000 which i trust has a proper siren.
Any help or advise vs simply returning the product? thanks
@JLX wrote:
Well I have not tried the siren yet so I can't answer that. However, I to ordered the pro2 4 camera system and it came with the 4500 and not the 4000 base station that is shown. I called Arlo and was first told that the 4000 is the latest model which apparently isn't true? Wondering myself which base station is the latest/better one.
Some time during the production life of this Pro 2s, Arlo seems to have changed the base station to the same shape as the later Ultra and Pro 3 ranges. I guess it makes sense to have a production line making the same bits of plastic.
Old promotional material, and web sites, may well show the older device. Unfortunately, the official documentation may also be out of date on things like specifications. The new version of the manual does show both base stations. But the data sheet does not seem to have caught up.
As to which is better, that raises the question in what sense? These things evolve and generally improve as bugs get ironed out and enhancements added.
We need Arlo to check out the specifications for the alarm volume.
Just another user
Is it on full volume?
You can adjust it in the rules.
Just another user
I still don't understand which is better to be honest?
Arlo state that VMB4500 doesn't do 2K here:
https://kb.arlo.com/000062284/What-is-the-difference-between-each-Arlo-SmartHub-and-base-station
Yet they say they have the same functionality here:
This so Arlo! Its like buying products from a political party who only ever tell you half truths and change their story all the time!
Any thoughts on which one to hold onto?
@JLX wrote:
It's not confirmed yet that it doesn't do 2k and it is apparently the newer base station.
It's clearly stated here that the 4500 is limited to 1080p. https://kb.arlo.com/000062284/What-is-the-difference-between-each-Arlo-SmartHub-and-base-station
@JLX wrote:
Well aware, however depending on which Arlo representative you speak to they claim the units are the same with the exception of design changes.
I think the KB articles are better vetted than something a support person might say. FWIW, I also heard the the VMB4500 had the same features, but that was before the Pro 3 came out.
@JamesC : can you clarify whether the VMB4500 is limited to 1080p with the Pro-3 camera [or not]?
@JLX wrote:
So I tested the speaker on the cameras and when I talk it is so low you can barley hear anything. Any suggestions? It also sounds like alot of static behind the super low voice that comes through.
It's not a feature I use, but it appears to be a common issue with some Android phones (particularly Samsung). Headsets apparently work better.
There is no way I know of to change the phone's microphone level, so I don't think there is any workaround.
Same problem the siren is not giving more that 70dB.
No data avliable for the model on the web either.
Hi. Same low volume on base station siren. Didn’t even scare my dog. My base station is revision 2. VMB4500r2.
Found this!
It seems like a single base is not sold but additional cameras is.
https://fccid.io/2APLE18300391
My base is a VMB4500r2 and according to the link posted above ( https://fccid.io/2APLE18300391/Internal-Photos/Internal-Photos-4044849 ) it seems that it has not a siren!
When I activate the siren I can hear a siren sound which is not as loud as advertised (I double checked and it is rated 100 dB on the Amazon description, where I bought it from).
This is disappointing and I am thinking about returning it while I am in time.
If there is no siren where does the siren sound come from? I cannot see any loudspeaker either from the picture...
