VMB4500 Base station not syncing with VMC4030P Arlo Pro 2 Cameras
  • 5 Replies
  • 4485 Views
Retired_Member
Not applicable
Hello
I have a VMS4230P-100AUS  (Arlo Pro 2 VMB4500 with 2 camera set (VMC4030P cameras))
I have added the base station in the app (iphone), and also can see in my arlo account on the web
However I am unable to add the cameras
Here is what I have tried:
Start with the Base station with a solid blue light & fully charged camera
Add camera in app, Select Camera, Pro 2
Press Sync button on camera placed next to the base, camera light flashes blue
Base station flashes blue
The app searches but no camera found
Sometimes there is a rapid orange flash on the camera before the light goes out on the camera
Base station goes solid blue
No camera added.
I have also tried the above by pressing the sync button on the base (base light flashes blue)
And the sync button on the camera (next to the base), light flashes blue
But still no camera is found
I have tried resetting the base (with a paperclip) for 10 seconds until the light changes to orange
Re-add the base, update firmware again and try the above again, but no success
Any suggestions on what to try next?
Retired_Member
Not applicable
Issue was solved with Arlo Chat
Full network & base station shutdown
Hold base station reset for 1min
Sync camera with battery out plugged into power
5 REPLIES 5
As strange as it may sound, temp unplug the ethernet and then press the base sync button quickly and then the camera ( with camera about 6 ft away from base, farther away from main router )...if the camera blinks fast blue then plug in the ethernet again
OR
Move the base as far as possible away from your router and manually do a sync as above...
I have seen when there is to much wifi interference the cameras have trouble syncing
Retired_Member
Not applicable
@TomMac I tried the above, base station and camera are in a adjoining room from the router
Not conjested wifi here as in a suburban environment
Sorry, that's all I got !
Retired_Member
Not applicable
UlfGK
This helped me, thanks! One camera synced after many tries, but efter I turned off the WiFi on my router all cameras synced fine on first try.
  • 5 Replies
  • 4486 Views
