I have 2 outside camaras and 2 inside. how do I set a mode to only use the two ouside camaras armed
Read the FAQs here on creating and modifying modes. In the Mode tab, click on your base and create a new custom mode. Only select the cameras you need for that mode - any camera without a rule is disarmed. Use the schedule to automate switching modes.
I did create a mode for 2 cameras after I discovered that you can add the 2nd camera after the first camera mode is set, Thanks
