VMB4000 Base Station won't detect device or update
base unit wont detect device or update
make sure the unit is plugged into the etherenet cable to router before turning on power
if using an app, try the web access https://arlo.netgear.com
thanks
thank you very much to the heads up on ethernet cablr before power on
