VMB4000 - Arlo Base Amber light
  • 1 Reply
  • 1473 Views
ARLOOOO
I have gone thru the forum and follow all the suggested steps, apart from resetting the device which I'm trying to avoid re-sync all the cameras since it's been installed 7m high around the house.
Is there a way to sync the base and camera's with taking the camera's down?
How I wish I went for the cat 6 hikivision camreas now, it doesn't look Arlo is making anything easy! and I really hope this is a one off thing. (which doesn't look promising it started occuring after 4 months of use)
You haven't told us WHICH light is amber - makes a huge difference as to the response.
  • 1 Reply
  • 1474 Views
