Arlo|Smart Home Security|Wireless HD Security Cameras|NETGEAR
The Arlo Community
Learn, explore, ask questions, and connect with our community of customers and experts.
  • 2 replies
  • 919 views
  • 0 kudos
  • 2 in conversation
Top Contributors
Caught on Arlo Video Contest
Share Video
Share Your Video!
Caught something cool on Arlo? Share it with the Arlo Community.
Post a video
VMB 4000 Arlo Base Station
Hello, I have the Arlo Pro 2 system with three cameras. How do I activate the siren on the base station. When I push the alarm button in the app the siren alarms directly without any mowement activity registrerd from cameras.
I am grateful for a solution.
Model: VMC4030P| Arlo Pro 2 Wire-Free Cameraarlo.netgear.com | Web Site/App
Message 1 of 3
Highlighted
brh Master
Re: VMB 4000 Arlo Base Station
I am not sure I understand you - what I think you are saying is that you can manually activate the alarm but can not activate it when motion is detected.
Press the Mode button at the bottom of your app screen.
On the next screen select your Pro base station. On that page, select the green pencil icon to the right of the Armed text.
The next screen will say Edit Mode at the top of the screen. For each camera in the Rules secton select the green pencil next to that camera's rule.
On the next screen, scroll down until you see the square box to the left of where it says Turn Siren ON and select it. Then select the pencil to the right of that text and set the volume level of the siren and the duration.
Hope that helps,
Brian
Message 2 of 3
All Replies
Highlighted
brh Master
Hope that helps,
Brian
Message 2 of 3
Done, thanks a lot it works perfectly.
Message 3 of 3
