I have 4 - Pro 2 cameras with an Arlo solar charger on each (+$300 when new) . If I upgrade to the Pro 5S, is there an adapter so they are useable? if not, there should be! There also should be a easier way to obtain support which is leading me to believe Arlo may not be my choice when upgrading my home security cameras.
Unfortunately, no.
Unfortunately, no.
That is unfortunate and thank you for the support. I will continue to use my Pro 2's and transition into another camera which does not use (and hopefully wont switch to) proprietary charging systems.
