Upgrade base station question?
  • 2 Replies
  • 3073 Views
JGP7229
Have had 5 Arlo Pro 2’s and looking to upgrade a few. I believe the newer cameras require an upgraded base station. My question - are the newer base stations compatible with the older products?
Yes.... the newer base will work with the older cameras.
Just be aware that after the trial period, the newer cameras will need to be on a paid plan to function as normal.
( ad may include the older )
JGP7229
Thank you
I currently have the Premier Plan, just to confirm there wouldn’t be an additional subscription needed as it states it supports 10 cameras. The newer cameras would just add to this current plan I would think.
Thanks again!
  • 2 Replies
  • 3074 Views
