Unable to recharge batteries
Hi ,
I haven't been able to use my ARLO Pro 2 cameras since the first time they ran out of charge. I want to know why I can't recharge them and have tried every way I can think of & suggestions from the internet. I've spent $800 so far but I want to know how to fix this issue before I buy any more cameras. Can you suggest what I can do or fwd this to the relevant area in ARLO.
Thanks Peter
@OscarBoots_23 wrote:
Hi ,
Can you tell us what you are doing to charge these things?
At its most basic, it should be a simple case of connecting the camera to a USB charger.
Didn't the system come with a power adapter and a USB charging cable that you can use for this?
By the way your footer lists the VMB3000. Pro 2 cameras come with the VMB4000 or, more recently, the VMB4500. Not that it matters, but does that mean you also have some older cameras?
Just another user
Hi ,
I haven't been able to use my ARLO Pro 2 cameras since the first time they ran out of charge. I want to know why I can't recharge them ...
Have you tried these steps? https://kb.arlo.com/000059145/My-Arlo-Pro-or-Arlo-Pro-2-camera-battery-isn-t-charging-what-do-I-do
