Unable to 'factory reset' Arlo Pro 2 camera
  • 4 Replies
  • 1916 Views
  • 2 Likes
ngl1604
Last night I started to get notifications for one of my cameras repeatedly going offline / online. It usually has 2/3 bars of signal strength. All other cameras are OK.
This morning I thought I'd look into it.  I rebooted the base station but the camera didn't come back online. I removed the camera from its mount and placed it right next to the base station and tried to sync but still no joy.
Finally I tried to follow the factory reset process but no matter how long I hold the sync button for, it doesn't display an amber flashing LED.  I'm confident that the button is working as it responds to a short press and tries to sync.
Any ideas?
Yes, I believe that is a mistake in the documentation.
You can try just removing/reinserting the battery to reboot the camera - but holding the sync button down won't accomplish anything.
ngl1604
Thanks,
Unfortunately, that news doesn't help me re-sync my camera though ☹️
I have removed the camera from the app too
What process are you using to re-add the camera?
ngl1604
I removed the camera via the app. I the. Tried to re add it using the app. When that didn’t work, I pressed the button on the base (flashing camera light) and then tried to sync. On both occasions, the camera timed out (fast flashing amber) without connection.
I’ve restarted the base unit a couple of times. The other three cameras I have all seem to be fine.
  • 4 Replies
  • 1917 Views
  • 2 Likes
