Last night I started to get notifications for one of my cameras repeatedly going offline / online. It usually has 2/3 bars of signal strength. All other cameras are OK.
This morning I thought I'd look into it. I rebooted the base station but the camera didn't come back online. I removed the camera from its mount and placed it right next to the base station and tried to sync but still no joy.
Finally I tried to follow the factory reset process but no matter how long I hold the sync button for, it doesn't display an amber flashing LED. I'm confident that the button is working as it responds to a short press and tries to sync.
Any ideas?
Yes, I believe that is a mistake in the documentation.
You can try just removing/reinserting the battery to reboot the camera - but holding the sync button down won't accomplish anything.
Thanks,
Unfortunately, that news doesn't help me re-sync my camera though ☹️
I have removed the camera from the app too
What process are you using to re-add the camera?
I’ve restarted the base unit a couple of times. The other three cameras I have all seem to be fine.
