Unable to add any cameras to Base Station. Tried restarting Base Station/WiFi/Phone/Arlo app.
I just picked up an Arlo Pro 2 kit with an additional two Arlo Lights for my home.
Previously I had the original Arlo cameras and base station, which worked completely fine!
Unfortunately, I am completely unable to add any cameras to the base station. I actually had some trouble connecting the base station, but after several restarts and factory resets, I got it to connect. I was also able to add the Arlo Light Hub and Arlo Lights without issue (yay)!
Steps to reproduce:
- Launch Arlo app
- Click Add a Device
- Click Cameras
- Click Pro
- Click Pro 2
- Once it detects my base station, click Continue
- Click Continue on battery screen
- Press the Sync button on the Arlo camera (the blue light does start flashing)
Expected: The app will discover my device and add it to the system
Actual: The app just says "Discovering your device. Please wait. until it times out.
The same occurs when trying to add original Arlo cameras (obviously selecting that option).
I have tried the below, none with any success:
- Restarting base station
- Factory reset base station
- Restarting phone
- Removing/reinstalling camera batteries
- Restarting Wifi
- Restarting phone
- Logging out / logging in to app
- Uninstall/reinstall app
- Moving camera closer to base station
- Moving camera further from base station
- Pressing sync on base station, then sync on camera
Environment details:
- Google Wifi
- iPhone X
- VMB4000 Base Station
- I am able to see the VMB4000's wifi SSID broadcasting
Thanks for any help, I am at a complete loss as to what the problem could be!
Try adding the cameras using the web interface ( https://my.arlo.com )
Still, going that route ends up the same - it seems that it just can’t pick up the cameras.
Maybe it's time to try support next: https://www.arlo.com/en-us/support/contact.aspx
Or just exchange the new kit with the seller.
Yep - I submitted a support ticket last night as well.
