Guessing it will come back in another update??
I could be wrong but I think the Call a Friend is part of the ARLO Smart feature suite. Which seems to be having issues for the past 4 to 5 days. I was informed by Tech Support that they are aware of the ARLO Smart issue but don’t have an idea of what the true problem is. In fact 3 of the 5 reps I talked to were not aware of it and sent me to their billing department blaming them.
Thanks so much for the reply! I hope they get the problem solved soon.
Hi everyone,
To set up "Call a Friend," make sure you go to Settings > Call a Friend (for Arlo Smart users) on the Arlo app to set up "Call a Friend".
Once you finished setting it up, you can click on the red shield icon on the top-right corner and tap on "Call a Friend."
Just to confirm, do you currently have Arlo Smart subscription?
My subscription was due to expire in a week so I updated it and, lo and behold, the setting for Call a Friend reappeared with the previous phone number in place. Hmm.
Looks like my issue is resolved.
Regards,
Allen
Same issue here, the tech support kept trying to get me to reinstall app/ restart phone/ or check the settings. I told them that they probably needed to reset my subscription but they said i had to cancel it first. Im on the 3 free months subscription and they refused to honor the discount once i readded the subscription eventhough its an issue with their system. they kept trying to blame my phone eventhough it worked before. complete waste of 1.5hrs.
Thank you!!
Hi everyone,
Our development team is aware where some users are unable to access "Call a Friend" with subscription and is currently investigating the issue. We will provide any update as we have more information to share. We appreciate your patience regarding this.
