USB Storage Drives, installing Seagate 4 TB questions
  • 4 Replies
  • 1892 Views
  • 5 In Conversation
a_kimpton1970
I’m thinking of installing a Seagate storage device onto my Arlo Base station and Arlo Pro 2 Cameras.  At present I have cloud storage through the Arlo.cm website but I’m wondering if anyone can advise of problems they may have encountered
 and if It affected the Cloud Backup for 7days
thanks
TMK, the max supported size is only 2 TB  ( due to the max size of a fat32 formated section )
To be clear, the USB drive has nothing to do with cloud recordings - it's a backup. ANd even a 2TB drive is gross overkill for almost every situation - it would have years of videos stored in most cases. A 32-64GB thumb drive is cheaper, easier to mout and dismount, takes less space and will hold an awful lot of videos.
michaelkenward
Sensei Sensei
Sensei
I'm with @jguerdat on the size of the USB storage. I step in only to say that if you really want to record local life for as long as possible, some people use 128 GB drives. (Perhaps they have access to free USB drives.)  The largest I have seen reported is 256 GB. But that is for cameras with higher resolution, and larger files, than Pro 2 cameras. I don't know if they would work in a Pro 2 hub.
Just another user
It should, since we are talking about a USB hard drive or thumb drive - not the micro-SD card that the ultra base uses.
  • 4 Replies
  • 1893 Views
  • 5 In Conversation
