UBS Weather Plug Arlo Pro 2 Camera
  • 2 Replies
  • 1212 Views
Flippit
Hi,
The USB Weather  Plug on my Arlo Pro 2 Camera has come out of the camera. How can I get it to go back in?
If a small, thin tool (toothpick?) can't be used to get it back into place, you may be able to just get it to plug the port without it being tethered. Or put some tape over the hole.
Flippit
Hi,
I tried for about 15 minutes using a paperclip but no joy so I put the plug in without being tethered and put a bit of tape over it. Works ok.
But I was hoping you had a magic method to re-install it properly.
  • 2 Replies
  • 1213 Views
