@Jyscit wrote:
I have two Arlo bases, let's call them base 1 and base 2. .
What is the model of the base stations? If you don't know, please check them for a label that starts with VMB.
It would also be helpful to know the models of the cameras.
@Jyscit wrote:
Currently, all cameras on both bases detect and record and recordings can be seen online at my account BUT the recordings on base 2 do not show up on my phone app.
I'm a bit confused on what you mean.
- Are you saying you can see base 2 recordings in the web browser (my.arlo.com) but not in the app?
- Are you saying that you can see the base 2 recordings in the app, but base 2 cameras cannot be filtered
Also, do you have a subscription for the cameras on base 2?
Thanks for getting back to me.
"Base 1" is a VMB4000.
"Base 2" is a VMB4500.
Recordings from cameras on both bases are available online.
Only recordings from "Base 1" is on my phone app.
I have a subscription plan for 8 cameras, enough to cover all the cameras on both bases combined.
Thanks.
Thx for this info. With these two bases, both the app and the browser are accessing cloud storage. Since the browser is able to access all the recordings, the problem must be something in the app.
Is the phone app using the same account/password as you use in the browser? Or is it using "friend" access?
