Trying to find Arlo Pro 2 outdoor mount that will allow camera to be secured and plugged in
I am wanting to mount my Arlo Pro 2 cameras outdoors connected to AC power but have had no luck finding a mount that will allow camera to be secured in the mount and plugged into weatherproof adapter. Installation is in a rural area with lots of wind so I do not trust using an outdoor magnetic connection on the mount. Anyone have a solution they have discovered for similar situation? Thanks for any help you may share.
FYI, any normal threaded camera mount will work. It is a standard threaded 1/4-20
there are so many choicesout there
Also, the newest little screw mounts from Arlo appear to allow room for the cable. They don’t have a retaining nut to get in the way. The ball mount is fairly high friction, so you just tighten the camera on the screw and keep rotating until you get in the orientation you want.
Will take a look. Thanks!
