Trying to connect Pro 2 cameras but blinks blue and then orange. Doesn't connect to Base Station.
I just bought this system I connected the basestation to the router and found it in the app .. but when I try to connect the cameras it just blinks blue for a while and then orange .. the camera doesn’t connect to the base station .. any tips ?
Try to sync without the app.... pull battery and then replace to reset cam
Quickly press the base sync button ( don't hold ) then a sec later press the camera sync button...
slow blue to fast blue after about 5-10 sec means it worked
