Trying to add 2 more cameras & it Requires paid plan
  • 9 Replies
  • 2046 Views
SarahBM
I have brought Arlo PRO 2 from Amazon, with 6 cameras, since about 3 years. I was using only 4 cameras. Now I needed the other 2. When I tried to add the other two, the sixth camera could not be added. They asked me to subscribe to a plan. Why ? I have brought 6 cameras so that no need for any new plan or paid plan, why now am I asked to pay more?
9 REPLIES 9
Generally the limit for the free 7 day cloud storage is 5 cameras per account.  But there were some kits that provided this for 6 cameras.  While the Arlo cloud should have figured this out, it sounds like it might not have in your case.
I think you will need to contact support for this - which is not easy to do w/o a paid plan.  I'm tagging @JamesC and @ShayneS in hopes they can facilitate.
ShayneS
Hi @SarahBM
Are you still experiencing this issue?
SarahBM
Hello
Yes
ShayneS
Hi,
Do you happen to know the Product SKU that you purchased? Did you purchase this as a 6 camera kit?
ShayneS
The basic plan allows for 5 cameras, you would need to purchase a subscription to add the 6th camera.
SarahBM
I brought it as 6 kit of 6 camera
I believe you would have been directed to use a specific code or model when first setting this up to get the special 6 camera free plan. I've never set one of these up so can't be sure on details. Unfortunately, now that it's set up, you've lost the ability to add that 6th camera for free, in my opinion.
ShayneS
I have escalated your issue. Arlo Support will be reaching out to you soon.
SarahBM
Still waiting for support
  • 9 Replies
  • 2047 Views
