Arlopro2 vms4430p firmware is 1.125.8.0-19174. I see on the image that it indicates " firmware update is required for your base station and camera. let's start with the base station". I perform the update it does its thing and indicates its updating however after it is completed it still indicates that a firmware update is required ??? plus I do not see any live stream options nor any push to talk icons.
Check your app version also. I think the missing buttons on shared cameras was fixed in V2.7.4 of the app (at least on iOS)
You might try power cycling devices to see if that helps with firmware updates.
