Tiny Torx screws on the back - size?
Something is broken inside my camera and I'd like to crack it open to see if it's a simply fix. To get to the 4 tiny screws in the back ( under the battery cover ) I need to modify a TORX BIT... anyone know what size before I go and modify the wrong bit? Thanks!
0 REPLIES 0
