Telephone wires setting off Arlo Pro 2
  • 1 Reply
  • 790 Views
Ericsd05
Howdy Guys! Just bought the Arlo Pro 2 and I’m having issues with telephone wires setting off the cameras. I know I know I can plug it it in and set zones but I rent and cannot drill holes to run wires. I have temporarily moved the camera and mounted it on my fence but I’m worried about it being stolen. Should I just give up on having a camera in the backyard and move one camera inside!?
ShayneS
Hi @Ericsd05
Have you tried to lower your sensitivity to combat the wires? you can turn it down by 1 value until you receive the desired results. If possible you can adjust the camera angle down a bit as well.
  • 1 Reply
  • 791 Views
