There have been many threads and posts about issues with the Pro 2 cameras.
Reply and add your comments if you are experiencing any of the following:
1. Single camera going offline
2. Multiple cameras going offline
3. Single camera going offline and battery draining
4. Multiple cameras going offline and batteries draining
I'm 4.
So far 3 of the 4 cameras have gone offline (multiple times each) and suffered battery draining down to 0%.
Clearly there is a major issue with the new devices - it could be software, firmware, or hardware.
Netgear are obviously aware of the problem now but just how widespread is it?
(Threads of this natiure would be so much easier of this was proper forum software with support for polls, etc.)
I'm #3 too. Out of my two cameras, one is been going offline, the other one is runing fine for now (3days).
I am #3 also, I have 4 camera's and 1 is draining battery fast and loosing connection, unacceptable for the money I paid.
Im #1, #2, #3 and #4 as I have purchased and returned the Arlo Pro 2 2-pack twice already. These problems have persisted every time, as well as the very bad night vision.
I've escalated the feedback on this topic to the product management team. The engineering team is currently investigating the concerns being discussed here and I will provide an update as soon as I have more information.
Yes I have also had to reset 1 camera after 1 day of use. Mine are also all plugged in.
I'm #3, have had 2 different Pro 2 cameras go offline and drain the battery to 0% over the past week. Never more than one offline at a time so far...
I just upgraded to the Arlo Pro 2 (2 camera set with new base). Setup was easy and they were working great. I use one inside and one outside. On the first morning, the outside camera went offline right as I was leaving for work. So was off all day. i tried rebooting the base station remotely and the inside camera would reconnect, but the outside camera would not. I reset the camera that night when I retruned home from work. It was working fine. The very next morning (today actually), the coutside amera went offline about the same time as it did yesterday (right when I am going to work). The inside camera is still fine.
When I get home from work tonight, I am going to switch the 2 cameras and see if that helps. I am wondering if it's getting out of range of the base station. Although, I have had the original arlo cameras for the last year or so. My camera went offline maybe twice in that time. Not daily like the Pro 2 is starting out doing.
Well I will give it a couple of weeks to see if there is any improvement. If not, then i return them back to Amazon because for this price, this is completely unacceptable.
There IS a possibility it's postion. If you don't actually eliminate it as a possibility, you can't definitively state it's not the position. Swap acmeras to determine this.
@jguerdat Already swapped cameras in my situation, just as others have stated they've done.
Read the other thread about the issue. "Yet another camera has gone offline"
Mine is going offline and the battery is draining in less than a day. It looks like my IR is staying on all the time. Could this be the issue? Also I have a giant black ring around the whole image. It looks like the camera is seeing the rubber/plastic ring around the lens.
My comment was generic. Not everyone has swapped cameras so can't be discounted.
Hi all,
A new FW was released last week (your system should have auto-updated), and I wanted to follow up and see whether you are still having the battery drain/offline issues.
Thank you!
Dawn Marshall
Community Manager, NETGEAR
I had the same problems with the new firmware.
I returned everything last week and got a refund.
Since 15483 (new firmware) been up for 8 days. Things are looking good!
What is the new version? I'm on 1.092.0.5_13833
Thanks for checking in and letting us know.
Check the Release Notes section here. That has the latest versions listed although sometimes it takes a day or two to see the update.
You seem to be referring to a Pro 1 camera, not the Pro 2.
Sorry, it is the Arlo 2. Even double checked. That is the version of firmware I have on it. I'd attach a screenshot, but not seeing a good way to show version and firmware.
Mine is at 1.124.1.0_15483. What you posted is what I have for a Pro 1.
Try removing the camera from Settings, My Devices and resync it. Update firmware if prompted and check again.
