Sporadic motion detection notification. Tried adjusting the motion sensitivity. Reset Base Station.
It’s been two days now that my 2 arlo pro2 Camera Just sporadicly giving me notification. It’s been installed on the same location for 1yr now and notice that only my other camera giving me notification (ring doorbell) I adjust the motion sensitivity and both camera confirm motion sensing. I rest multiple time the base station and that seems to do the job for couple of hours. Then there will be no motion even I tested it myself over and over. Nothing has change couple days ago in terms of settings, distance with the base stations or my internet connections. Please be advise.
Hi Emorehs,
Are you still having problems where you're experiencing sporadic motion detecitons from your Arlo Pro 2 cameras? The minimum operating temperature is -4°F (-20°C). What is your signal strength showing for your cameras?
