I've been successfully using the Arlo 2 and 4500 base in geo fencing mode, this works well when leaving and returning to the property, arming and disarming the internal cameras.
I now want to introduce a third camera. This camera will be outside and will cover the garage side door and patio area. I want this to be armed when we are asleep for example/ overnight. But whilst in geo-fencing mode it will not work, we are in.... How can I achieve a hybrid setup here without having to change the mode manually for the whole system. Can you split things or have the camera work independently, or do you need a separate base station on a schedule for outside, to cover overnight.
If you can’t split the home/away settings in geo-zone to work for you, the yes you can add a third base for the extra camera. ( since a base can run only one schedule at a time )
There’s no limit as to the number of bases... I’ve run 3 at one time and do find the option to run multi schedules are an advantage...
and/ or splitting the cameras to like front- rear yards
OK, thank you for this
I think there's scope for Arlo to extend the scheduling and options here, it can't be uncommon to rely on Geo-Fencing when you're out but equally have some piece of mind with a schedule, when still in, controlling for example an external camera.
Tom
