Speaker cracking
I have been able to replicate your workaround for AC powered cameras although for me the noise returns within 24hrs.
I have been using smart switch’s to power cycle the cameras and observed that power cycling every 6hrs seems to keep it from recurring.
Thanks for the heads up on the work around.
Fixed repetitive scratching or crackling sound on Pro 2 - Much appreciated!
Released 21 Mar 2020
My static has not gone away, it is just as loud as it has always been. I am on android as well, but this isn't a problem with the app, because the static sounds come from viewing my cameras on multiple PCs as well.
The static/scratching is gone from all 5 of my speakers too. ....Thanks!
What was causing this issue?
yeah my firmware is updated, I even restarted the base station just in case. Still have the static on my cameras.
What is the specific fix for the above - haven't seen one that applies to PRO 3 and Base station 4540 with iphone
I have two cameras on ac and only one has the crackle. It’s there all the time for as long as I remember. Never even once on the other one.
And out of three on batteries, one, the newest add on, has crackles on and off.
Yes I have the latest updated software.
