Solar panel question
  • 1 Reply
  • 976 Views
Mcnasty13
Hello, has anyone had a issue with moisture getting in there solar panel? If so is there anything I can do to fix it or is it just trash now.
At a connector or from the assembly of the back and front pieces? After drying it out thoroughly you could try wiping a thin coating of silicone rubber on every seam. You may also find a crack while doing this that could be causing the problem.
  • 1 Reply
  • 976 Views
