Solar Panel Charging
  • 1 Reply
  • 1122 Views
BlueIguana
"A charging fault has been detected. Unplug and reconnect the charger from the camera side of the plug. If this error message persists, see KB article for Charging Faults."
I would prefer to buy a cable and see if that is at fault. I guess ARLO don't do that and want you to spend another $80 on the solar charger.
That won't happen until i know the cable is not the issue. I'd rather buy an alternative camera and that out should the solar panel have failed
Summary
Can't find the article
Camera is fine (recharged battery with supplied wall charger, been monitoring activity for 4 weeks,solar panel is still plugged it, continue to get the above message)
Cable is not damaged per visual inspection
I suspect the panel and/or cable have become faulty. They are located 15' above ground so nobody can touch them.
Worked for just under a year
Stopped charging in September
Rather than spend
JessicaP
Hey @Bluelguana,
You can refer here if your Arlo Solar Panel is not charging: My Arlo Solar Panel is not charging my Arlo Go or Arlo Pro camera battery; what do I do?
  • 1 Reply
  • 1123 Views
